Vs v6 no power to coil pack
Sam Jones
Darwin
1996 v6 vs
Hey guys, my vs v6 was driving fine parked it up and now it will turn over but there is no power getting to the coil packs so no spark. I have been told crank angle sensor but all the research I have done on this site suggests that the car would have stalled if this was the issue. Seems immobilizer related or something hopefully simple but it has me stumped. Any help would be hugely appreciated, cheers
Trevor loves holden.
vs commodore
I imagine you checked all the fuses and relays to count them out first, also did you disarm your car with fob? Does your passenger side door when open have a over ride key some had them Vr did? Have you tested the red wire on your DFI harness for 12v?
Sam Jones
Darwin
1996 v6 vs
Found the issue, ants simultaneously destroyed 3 of my relays so when testing I was swapping out bad relays with other bad relays and took a while to figure this out, thank you very much for your help
