Vs v6 shocks help
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by vs v6, Apr 6, 2011.
  1. vs v6
    vs v6 New Member
    australia
    vs
    Hey guys, i just brought some monroe gt gas shocks for my vs because i got ultra king springs and got told i need new shocks as the ones i got are to big which are not allowing my car to sit low enough.
    Monroe - GT-Gas
    Did i do a mistake buying them and not these?
    Monroe - GT Sport
    seems to me that the monroe gt gas stocks dont make your car lower but the gt sport ones do?
  2. vs v6
    vs v6 New Member
    australia
    vs
    anyoneeeeeee?
  3. 97VSV6
    97VSV6 New Member
    VS EXECUTIVE
    Gt Sport Are just a better shock they are not shortened
  4. vs v6
    vs v6 New Member
    australia
    vs
    oh ok thanks
  5. EDGE3
    EDGE3 New Member
    NEWCASTLE
    1997 VS COMMODORE,1996 GTS-R COMMODORE
    It would be better to get shortened shocks aswell but not necessary,the only thing is if you use standard shocks theres a chance they might pop out if you hit a pot hole.And also lowered springs make the car lower not shocks
  6. vs v6
    vs v6 New Member
    australia
    vs
    The why in the world is my car still not low enough and is sitting on ULTRA LOW KING SPRINGS? must be the shocks?
  7. glenn l
    glenn l New Member
    ve sv6
    gt sport are a short bodyed strut and are valved different to suit a lowered coil.
    and shocks will not alter height, unless you have a factory hsv 19" wheel strut where the spring seat is 10-15mm higher.
  8. EDGE3
    EDGE3 New Member
    NEWCASTLE
    Your springs arent low enough to your liking so get ones that are even lower,once again its not the shocks mate,but like I have said you need to have shortened shocks with lowered springs but people will tell you that it isnt necessary.As glenn l has said get bigger wheels then it will look more lowered
  9. vs v6
    vs v6 New Member
    australia
    vs
    I figured the problem.
    It was the shocks!
    i got monroe gt shocks and now its just low enough top of the wheel which is perfect
