VS V6 supercharger cuts out under boost
teocali76
muswellbrook
vs series 2 v6 auto
hi i know its late but i did notice that your valley manifold has a vacuum hose that is not connected and i can see it next to the supercharger.
noddys VP
Geelong vic
VR BT1 V8
I am surprised not more people has noticed this, Injectors, fuel pumps, spark plug gaps etc don't matter when it comes down to the boost of a supercharger. turbos yes but not superchargers. the more the supercharger spins the more air it displaces and the more boost it makes. for the problem you have is the pulley is to small or the supercharger is to small for the motor. basically you should find at about 3000 rpm at light throttle the boost should be higher than at flat out. This indicates that your motor is sucking more air than the supercharger can provide to maintain higher boost. the next thing is air leaks especially the boost bypass valve used for at idle, if its plumbed in wrong you can loose boost there as it bypasses. Also Has it got a standard cam? Little known fact cams for super charged cars and N/A cars are very different, They change the valve timing and over lap to change your dynamic compression threw out the rev range. The result of the wrong cam shaft will cause a loss of boost because the valve over lap and you sending the pressurized intake manifold pressure straight out the exhaust. Commodore V6s have this problem because they run lots of valve overlap. Its something many people over look when supercharging an engine.
goldcoast
supercharged vt II acclaim
why dont plug gap matter with a blower but does with a turbo?? confused.... they both blow/force air in.... didnt think it mattered if it came from ya ass...
noddys VP
Geelong vic
VR BT1 V8
Basically i will simplify it for you. Supercharges run off of the crank easy, turbos run of the exhaust, now here we have a variable. A missed or poor power stroke wont effect the supercharger because remember it runs off the crank. The turbo though wont spool as well because the exhaust pressure is lowered because of the failed or uncomplete exhausted compression pressure. Thats your variable. Make sense now. Fuel inhjectors spark and all this stuff is more vital for a turbo. More variables. ( sorry about spelling mistakes and grammer did this post on my phone).
menace2sobriety
West Auckland
2003 VY soon to be boosted
WAFFEN SS, I am in Auckland and am now doing exactly what you have done, just wondering if you could help me out by supplying me with the mounts and tensioner pulley setup needed for my Ecotec engine, also what belt did you use, was it the original or off a SC V6? thanks
