vs v6 taping noise
C
crzyvs
Guest
hi people i have a vs v6 when i start the car it makes a taping noise for a few secons n then goes away...i give it a rev and as the revs are goin down it make the tapin noise again ..it sound like it coming from the auto or the sump .. please help
ENV5
VS Exec, VC SL/E V8, 2x Lada Nivas
sounds like your lifters and rockers are wearing out
C
crzyvs
Guest
ohk thanks mate... it also spit out black stuff out of the exhaust ..blows a lil bit of black smoke round from 3000 rpm and up ...could enyone tell me y it doing that thanks
C
crzyvs
Guest
and it also rattels when im goin 20-50kph only on low revs ?? im sure some knows what its is
hako
Donating Member
80
Toowoomba SE QLD
VS11 BT1 V6
If it was an old flathead V8 I'd say it was low oil pressure causing the conrod bearings to rattle - how many Ks on the motor?
hako
Donating Member
80
Toowoomba SE QLD
VS11 BT1 V6
And does it use oil or coolant or overheat? Has this problem happened suddenly or after doing something 'different'. Dont like the sound of the black stuff spitting out the exhaust as that could mean a head gasket or worse but that shouldn't cause a rattle. You could try a heavier grade of oil - maybe the stuff designed for older cars which most of our cars are.
C
crzyvs
Guest
yes it does over heat n use oil last time i changed it only had 2 n half litres n im usin thicker oil aswell 25-40 i think
hako
Donating Member
80
Toowoomba SE QLD
VS11 BT1 V6
Unfortunately it sounds like you may soon be spending some $$$ on an overhaul or a 2nd hand motor. Probably also a new radiator etc also. These things mount up and always cost more than you initially bargain for.
Bottom line is that it is probably cheaper and easier to buy another car....but, in the meantime go for the heavier oil for old cars as that may give you a bit more time. Good Luck.
holden007
VRII
Subaru Liberty
197,000k's and causing all this, my friends ex-taxi @ 625,000k's started tapping and black smoke, just got another ecotech engine from the wreakers, only done 30,000k's and put it on, all sweet.
