VS V6 Ute Running Very Rough
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by jwaye2, Jul 20, 2011.
  1. jwaye2
    jwaye2 New Member
    Darwin
    VZ Alloytec Sedan, VS L67 Ute
    hi having some trouble with my ute.
    Its running very rough in idle and worse while driving and has lost alot of power. ive done every check i can think of and cant figure out what it is. and there is no error code showing.
    Can anyone help please
  2. 304runner
    304runner ( .Y. )
    Central Coast NSW
    VR 5.0 Ute & a 4runner with a VS SS trasplant
    Have you filled it up with fuel lately? Perhaps bad fuel.
    Could even be bad spark... Or another 100 things...
  3. jwaye2
    jwaye2 New Member
    Darwin
    yer i filled up a week ago. it worked beautifully for 3 days, went to leave for work next morning and its been running like **** since
  4. vs-v8-ute
    vs-v8-ute New Member
    nsw
    vs commodore ute
    how low did you let it get before you filled up you may have picked up some crap off the bottom of your tank and possibly blocked an injector
  5. PRAVX II S
    PRAVX II S Member
    Australia
    Commodore
    I dont know what test you did but check fuel pressure. How old is your fuel filter that might need changing.
    Also check some of the vaccum lines in the engine bay.
  6. jwaye2
    jwaye2 New Member
    Darwin
    This may help with diagnosing the problem. now i have white smoke coming out of the exhaust
  7. 304runner
    304runner ( .Y. )
    Central Coast NSW
    When the car is hot or cold? Does it go away after a while of is it happening all the time?
  8. jwaye2
    jwaye2 New Member
    Darwin
    it first started as light smoke when i was sittin in idle for a while and it got really thick and white after a couple mins waiting for traffic to move. pulled over and left car turned off for 15 mins and continued home. got a little bit of smoke on the way but not very thick. havent risked turning it on again since :(
  9. elmaso
    elmaso Member
    VS berlina
    that seems like a gasket/seal has gone somewhere.
  10. 304runner
    304runner ( .Y. )
    Central Coast NSW
    Is it an Auto? Before you start pulling apart you engine have you looked to see if the transmission is leaking? This happened to a mates car the other week and the tans fluid was leaking onto the hot exhaust causing smoke and a loss of power. Start by checking your fluid level but make sure the car IS running when you check it.
  11. jwaye2
    jwaye2 New Member
    Darwin
    its a manual. engine and gearbox have no leaks and no water in the oil. kinda spells like fuel when there is smoke.
