vs v8 lukey extractors
phear11
adelaide
vs 5L Berlina
just wondering has anyone installed lukey extractors on a vs v8 if so is it like the pacemakers where u need to remove the rack, and undo the drivers side engine mount and jack the motor up.
any other hints would be appreciated.
cheers jamie
Not_An_Abba_Fan
Exhaust Guru
Bunbury, WA
Strange Rover
You don't need to remove the rack and jack the motor up with Pacemakers. Drop the RH tie rod and that's it. You may have to undo the shaft linkage as well, but the last 5 or 6 sets I have fitted to the VS 5.0L, all I have had to do was drop the tie rod.
phear11
adelaide
vs 5L Berlina
ok thanks mate great to hear! hopefully ill be able to do the same with these lukeys.
i know the pace makers are meant to be better, but with a stock motor with exhaust and cai im guessing they wouldnt be much different?
Not_An_Abba_Fan
Exhaust Guru
Bunbury, WA
Strange Rover
Not a great deal of difference performance wise, just build quality.
phear11
adelaide
vs 5L Berlina
ok thanks, couldnt pass them up for $100.
