vs v8 statesman manual conversion engine light
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by manstato, Nov 7, 2012.
  1. manstato
    manstato New Member
    tumut nsw
    vs v8 statesman
    I have just converted my 96 model vs v8 statesman to a manual using a t5 box, the engine light is on yet the only problems i have is the tailshaft vibrates due to using the back half of the statesmans tailshaft and front half of the manual one i got witch should be fine after balancing, car runs perfectly fine and am extremely satisfied with the power after putting a tuned memcal ecu in it, just wanting to know how to get the engine light to stop cheers
  2. Jxfwsf
    Jxfwsf Well-Known Member
    Aus
    commodore
    more info needed, did you put a manual loom and ecu in? Use the auto loom and pcm? Checked for error codes?
    If it's the auto pcm and loom you've used then you need to have the memcal retuned to have all the auto error codes turned off as it'll be looking for something that is no longer there.......
