Hot-Rod
SuPaFlY -LiV3 Surviv3 Di3
- Sep 9, 2005
- 332
- 12
- 18
- Location
- Oz
- Website
- forums.justcommodores.com.au
- VX Commodore Series 2
Hi, im wonderingwhether i should do this or not. i have a VY series 2 2004, 100,000 km, it has been maintained well and doesnt appear to be leaking however im doing all the hoses and therefore coolant which costs a bit, so im wondering should i be doing this manifold set as well, even though its not leaking? do they all eventually fail or is it lack of maintenance and or earlier models?
thanks
Eventually they will fail. No need to do it if it isn't leaking. The original inlet manifold gaskets are plastic with rubber square seals and rubber seals on the front and rear of the manifold. Over time they change shape, the plastic splits and allows coolant to either leak into the runners or leak out onto the top of the motor. Same with the oil in the engine.
At a minimum I would torque the top manifold bolts that hold the manifold to the engine as they are a weake torque and are prone to coming loose. Bolt up 12 bolts on manifold to 12 - 16 NM Torque. Hope this helps.
