Most V6 Vs's wont do standies with the simple brake accelerate method, mine wont. from what im told the full lock to the left works, and i know that the old oil on the road trick works as well.....I think it has alot to do with the Electronic box. If you had a s1 Vn you would have no probs, i used to have one and you could spin em with ease. Another method....Although its highly not recomended is you stick it in N and bring the revs up, then slam it back into D without letting go of the revs, as soon as it starts spinning add in a little bit of break, will screw your gear box up fair quick if you do it too often, but if your desperate it will work.......
