vs wiper switch sedan to wagan
danny1987
vs commodore sedan
hi just woundering if the vs wagon wiper switch will fit the sedan as i wont to us it for a kill switch
markovr
62
northside brisbane
youtu.be
07vessv 94vr .04vz wgn,93vp wgn,82 vhV6 wgn 88 vn
Yep it is exactly the same as far as the normal wiper functions go wagon to sedan...it just has the function that reverses the polarity on the washer pump to when you push the stalk forward against the spring in the mechanism
The pump actually on a wagon pumps in reverse to squirt water from the resevoir along the length of the car to the back window normally.
danny1987
vs commodore sedan
so the wiring is the same?and will the time thing work so i can go slow or fast?
markovr
62
northside brisbane
youtu.be
If it has a thumbwheel for changing time interval on intermittent function it will not work on normal car with low or mid bcm...it will only work on high series bcms you get on calais or statesman or on some berlinas and have a loom to suit.
danny1987
vs commodore sedan
ok thanks so the normal wagan one will work in a sedan if i get the harness 2
markovr
62
northside brisbane
youtu.be
You just need a lugged wire that that will slip into the spare space (on a sedan) next to the lt blue/red wire in the connector box that plugs on to the wiper switch .It will have 12v on it when you push the stalk forward.
