vs wont change gears need help
htmunro350
SA
VP commodore,ht monaro
hi im new to the site i just brought a vs ss x chaser i got a flat battery put a charged batt in and now my auto wont change from 1st unless i fog it and the idle is up and down i got a mate to check the computer it comes up as code 12 i have been told to disconect the batt for about 10 mins then start it up hold it at 3000 rpm for a few minutes then drive it for about 50 kms to calibrate the computer is this true and how can i fix this problem it was running fine b4 i got a flat battery
need help on this as i need my car to go to work
cheers shaun
Krisp
perth
D22 St-r Navara
did you buy it c=from a car dealer?
htmunro350
SA
no i brought it private i have had it about 2 months and was running great until i got the flat battery
James39
Gave up on VL's
Newcastle NSW
1995 VS Acclaim & 1992 Holden Barina
Is the alternator working? Might be the reason for the flat battery.
My car would not change gears when my alternator failed as there was not enough power for the transmission.
Revs going up and down sounds like the TPS
justbad4you
IF YOR NOT A HOLDEN
MELBOURNE S/E BAYSIDE
97 VT BERLINA/ 98 VS SIII MALOO (RED) LX SLR5000
is everything done up tight on the battery>? are the battery lead ok?
htmunro350
SA
yes alt is fine leads are tight still need some one who has had this problem to help me
htmunro350
SA
please help some one must found a easy way to fix it i have checked the basic stuff as iv built a few motors but no injection stuff with computers even my mate that has this type of car says its something simple just carnt put a finger on it
code 12 its telling us
this is giving me the sh* ts as the local work shop is a major rip off and we are in the desert
PLEASE
shaun
James39
Gave up on VL's
Newcastle NSW
Well it would either be to the fact that is not enough power (Battery going flat due to no charge from the alt) or the TPS (Throttle Position Sensor) need to be replaced.
htmunro350
SA
and will this cause my idle up and down and gear changes to be up to sh*th ??? when the computer is telling us theres nothing wrong ????
shaun
James39
Gave up on VL's
Newcastle NSW
If the TPS is not working the gears will not change. it would be in limp home mode, same as when there is not enough power for the trans.
Just a small question for you, does the motor stop when you disconnect the battery terminal?
