Drag lc
- Jul 14, 2019
- 12
- 3
- 3
- Age
- 41
- Location
- gladstone
- vs commodore
hi,
just looking for some help as my everyday vs has decided to stop starting so symptoms are.
security light has stopped working
no cranking at all neutral or park
check engine light seems to be on with ignition on .
i tried to hot wire the starter with key in the on position the engine would crank but not fire.
now the key is in a pretty poor shape no buttons and sometimes i need to hit the unlock button to get it to crank if the security light stayed on.
but now with the security light out at all times it still won't crank.
i tried disconnecting the battery but nothing changed
i also checked the contact on the sign key with steel contacts it stays in contact at all times during key on and crank.
so I'm looking at best ways out of this do i get the computer modified to run with out bcm or do i try another bcm and key set?
any thoughts would be greatly appreciated.
thanks hayden
thanks hayden
