vs wont start
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by Auswaldo, Sep 6, 2012.
  1. Auswaldo
    Auswaldo New Member
    Queensland
    xh falcon ute
    so after changing the plug leads oil filter and earthing the 02 sensor, my car wont start, just sort of rolls over slowly and coughs a bit, need some help asap
  2. Brett_jjj
    Brett_jjj Well-Known Member
    Tamworth NSW
    vs commodore
    Where did you earth the 02 sensors? Was it anywhere near the ECU?
  3. Auswaldo
    Auswaldo New Member
    Queensland
    xh falcon ute
    yes, yes it was... there was a small hole in the body near the ECU and i was a tad lazy that day so i just earthed it their... i take it that may have something to do with it?
  4. Brett_jjj
    Tamworth NSW
    vs commodore
    Yeah, it might. Have a close look at all the wiring and connectors etc near the ECU, something might have become slightly disconnected. Also not all VS's need the 02 sensor earths modified, some VS's had a few problems with the ECU not going into closed loop mode with certain error codes setting, and the earth fix supposedly helped the problem. Also the ECU will see false voltage flunctuations in the 02 sensor circuit if the 02 sensors are not earthed directly to the engine block as per the factory setup. The extra earths are fitted along with the original 02 sensor earths left in place..
  5. hako
    hako Donating Member
    Toowoomba SE QLD
    VS11 BT1 V6
    If it just "sort of rolls over slowly and coughs a bit," then I'd suggest your battery may be on it's last legs - the electronics in Commodores needs a fully charged battery.
    I'd also doublecheck that the plug leads are on the correct plugs.
  6. Auswaldo
    Auswaldo New Member
    Queensland
    xh falcon ute
    i know the battery is quite sick, i dont know how well it holds charge anymore
  7. RX25SE
    RX25SE Real cars are steel cars.
    MY07 Liberty 30R Spec B 6sp wagon
    This......
    O2 sensor faults will not effect starting.
    They need about 300 deg before they come 'on line'.
  8. Auswaldo
    Auswaldo New Member
    Queensland
    xh falcon ute
    ok so i tryed her again today, after checking if all the wires were ok at the ecu, then nothing, then i checked to see if all plug leads were on properly, one wasnt that got rid of that horrible cough back, but she still didnt start, if i am correct the firing order is 1,4,5,2,3,6?
  9. Brett_jjj
    Tamworth NSW
    vs commodore
    The firing order is 165432 for the V6.
  10. aussie4life11
    aussie4life11 Keep It Simple Stupid
    Western Australia
    94 vr 3.8l v6 Auto Acclaim, 2002 Vy Exec Auto
    are the leads on the right spot on the coils. you should be able to see the numbers on the top. one side of your engine is even and the other side is odd. the lowest numbers like one and two are at the front while 5 and 6 are at the back
  11. James39
    James39 Gave up on VL's
    Newcastle NSW
    1995 VS Acclaim & 1992 Holden Barina
    Here is the cylinder and coil numbers.
  12. Gus The Snail
    Gus The Snail Born to be dizlegzic
    ipswich - on the right side of the tracks
    VS ute S2 1996
    ^^^ same as the old holden reds , 153624 , there should be numbers on the coils to tell you which ones go where.
  13. Jonah 101
    Jonah 101 Undefined
    Rotorua
    R32 Skyline
    I am wondering if the plug not being on properly has burned you DFI module out, I did that just last week by cranking the car over with a lead having nowhere to earth out...
  14. RX25SE
    Don't forget the waste spark system will fire every turn of the crank.
    Check you are getting a nice fat spark at the end of the lead.
    Can you hear the injectors clicking when you crank it?
  15. Brett_jjj
    Tamworth NSW
    vs commodore
    These numbers shown in the pic in your above post are the cylinder and coil numbers, not the actual firing order of the engine, which is 165432. And its not the same firing order as used on the old red holden 6's, they used 153624 for their firing oder..
  16. James39
    Newcastle NSW
    I edited my post....
    I only posted that up in case the OP had put the leads in the wrong order...
  17. Auswaldo
    Auswaldo New Member
    Queensland
    xh falcon ute
    ok... so it was my fault, after checking the leads again i foung out i had c couple of leads in the wrong spot, she will start again, but a new issue has arisen, it smells very rich
