vs wont turn over
laver
burn rubber not your soul
ballarat, victoria
vy executive
so the only time i touched the engine was to change it to a pod filter did it all right had it running for 5 mines then it cut out so and wouldnt start againg so i put the box back on and it doesnt even fire now =/ help please?
patskies
34
townsville
VT SS LS1 (vz monaro themed)
so your saying that it cranks but will not start??
first of all do a diagnostics check. this saves alot of time.
Bizmark
93' Pov-Pac
Were any hoses or sensors unplugged to fit the pod filter, you may have forgotten to reconnect something.
patskies
34
townsville
i too was thinkin the airflow meter
laver
ballarat, victoria
vy executive
some conections were unpluged but iv put them it but the crank wont even turn now
patskies
34
townsville
yes. battery prob hasnt got enough juice to turn the engine anymore
Constatiner
Mackay
vs commodore ute Series 2
could be your battery in ur key thats flat
Brett_jjj
Tamworth NSW
vs commodore
Powering up a radio is a world away from the power needed to wind over the engine via the starter motor.Try turning the headlights to high beam and then try the starter,do the lights go dim or completely off whilst trying to crank the engine? If they do,the battery is most likely buggered.If they stay bright,theres a bad connection somewhere between battery and starter or the engine earth side..
