VsMaloo clutch fork adjustments
97vsmaloo
Vs Maloo
I've just changed my clutch cable because I thought it was stretched but it's still loose in the bellhousing so I took the gearbox off and adjusted the clutch fork but the cable is still loose and its maxed out on the adjusting tread the dampener is on the cable everything is there I have no idea what else could be causing it to be loose
Any ideas?
Not_An_Abba_Fan
Exhaust Guru
Bunbury, WA
Strange Rover
Bent or cracked clutch fork? Not uncommon.
