VT 304 electrical problem
Discussion in 'VT - VX Holden Commodore (1997 - 2002)' started by skippy73, May 18, 2020 at 8:35 PM.
  1. skippy73
    skippy73 New Member
    townsville
    vt 5.0 ltr
    Driving home The other night an the car started spluttering and chugging really Bad Headlight dashlights went dull then stalls.
    Tried to start the car sounds like the battery is flat.
    open the bonnet seen the battery moved a bit and push the earth strap against the fan belt cutting half way through...
    some people gave me a jumpstart probably got another 4 km down the road,same thing..
    Drove it home in the morning stalling it in the driveway replaced all the wiring, it’s
    been doing the same thing ever since. took the battery to get tested the batteries 100% good..... does anyone Have a clue????????
  2. falcodore
    falcodore Member
    1998 Holden Calais
    Was the battery wiring fixed properly? I'd be following the wires a bit further back to make sure that nothing else got damaged. There's a possibility that something else was damaged while the battery moved, check the negative terminal too?
    Vin999 likes this.
  3. Vin999
    Vin999 Active Member
    SA
    Vsedan
    did you change the cut negative cable
  4. shane_3800
    shane_3800 Active Member
    places
    vr commo
    If you know how to check the VD across all high amp cables.
  5. skippy73
    skippy73 New Member
    townsville
    vt 5.0 ltr
    Yeah I replaced the whole wire cable from the inner guard to the battery clamp
  6. BlackVXGTS
    BlackVXGTS Well-Known Member
    Melbourne, SE
  7. Vin999
    SA
    Vsedan
    Some battery test ok but cant hold charge when used, if your battery is good and hasn't got any fried cells that drain and not charging then car stalls eventually, also if your alternator isn't charging same stall, it might have got a zap from your cut wiring issue. sort the battery and alternator first
  8. shane_3800
    places
    vr commo
    I've never had a battery make it past the load test that was dead. Either you're talking about a state of charge test or the load test has not been performed correctly.
  9. Trevor loves holden.
    Trevor loves holden. Well-Known Member
    vs commodore
    If the car was starving for earth it could heat up electrical parts frying them from lack of volts. Hope in your case its not.
