VT 5L Clubby, drinking fuel and gutless!!
Discussion in 'VT - VX Holden Commodore (1997 - 2002)' started by JMH, Aug 17, 2011.
  1. JMH
    JMH New Member
    Wodonga
    VT 5L Clubsport
    Hi Guys,
    Im brand new to this site so i hope im in the right area.
    I have a VT 5L Clubby engine in a landcruiser wagon. Marks 4wd adaptors disabled the security in the memcal. The engine runs and drives, but its very heavy on fuel and has no power. The car is duel fuel also and to put into perspective whats happening, The engine has more grunt and is better economy on gas than fuel!!!!
    When plugged into the scan tool, it will only recognise it as a VS v6 and even logs codes immediately after you delete them when car is turned off.
    ECU and memcal are originally out of an auto clubby but is now a manual in the landcruiser.
    The engine is freshly rebuilt (10 000km) old.
    Does anyone have any ideas of what to look for or what to try to get this thing running how it should???
  2. machone
    machone New Member
    VHSLE/VXSS/VXEXEC
    id be getting someone to be looking at your ecu mate and getting it to work for your application...you have a few variables auto ecu and now manual and on gas
  3. GEN3RATD
    GEN3RATD 100% Teflon
    Cannington, WA
    VE Maloo
    sounds like your regular 5L...
  4. calais24/7
    calais24/7 Mucca Mad Boys
    VS Calais II 5L, 98 rodeo v6
    oi none of that :p, remember 5l's were designed for roughly 1.5t cars, not heavy 4wd's
  5. HarmlessMuffinMan
    HarmlessMuffinMan Member
    Armidale, NSW
    VX Commodore 2002 Executive v6. Ex Patrol Car
    Nah I'm going with Generated on this (+ a 3 in there somewhere).
    Does indeed sound like an ECU problem seeing as its coming up as a V6? Thats obviously not right. As per power, there is probably heaps of it... I'm not 100% sure on the engines, but do have plenty of little neutons running around in the cylinders? Because land cruiser is like.. 2.4 ton? v Clubsport which is about 1.7?
  6. GEN3RATD
    Cannington, WA
    VE Maloo
    i think they were designed to keep boats from floating away.
