Mikecaprice
- Jul 21, 2017
- 88
- 28
- 18
- Location
- Adelaide
- vq caprice v8 vq v8 vs ss man
I have a vt 5lt and 4l60 in my vr ute running on a vs 5lt loom and ecu vs s2 Statesman dash and body loom climate control ect
It's got 2 intermittent issues
Won't idle or will idle high anywhere from 1000 to 2500 rpm and will hunt up and down at idle and while driving at set speed
Had an issue with it shifting hard and late new TPS seems to have fixed that for now have changed the IAC for several known working ones and a new one
Swapped out ignition module and coil for know working ones
Checked cleaned and added extra earth wires
Changed temp map mat sensors multiple times for known working ones tried 2 different vs 5lt ECUs
Cut out and replaced both the IAC and TPS wiring back past the fire wall grommet with
Done inlet manifold gaskets coolant ports where ugly on manifold changed manifold for another vt 5lt manifold drilled and tapped the single wire temp sensor and mat sensor and added port for map sensor
Still running the vt dizz with a 4 pin plug added to vs loom timing is spot on 10 deg
Alternator is putting out a consistent 14.1 to 14.3v
Has plenty of fuel pressure
Get no fault codes to narrow it down
Set up was running absolutely minty on a vt loom and ecu less than 6 months ago
When it's playing ball it drives well and accelerates fine wide open throttle it pulls hard for a 5lt
Had more than my fair share of commodores and 5lts had plenty of issues over the years always simple easy to fix
