VT ABS module
VT-MMM
VT - MMM
VT Acclaim S1
Hey my vt is doing some strange things all my warning lights are coming up and my aircon and cruise control is not working. Someone told me it was my ABS module does that sound right and does anyone know where i can get a cheap one in Perth.
Thanks any help will be useful.
snoopin99
Outer SE Melbourne
VT Calias S/C Series 1
Yup that's your ABS module. Exact same thing happened to mine. Try Repco/Bursons trade type auto stores, they do an exchange type swap over. Module is quite easy to remove, just need some Torx bits/drivers.
Good luck!
VT-MMM
VT - MMM
VT Acclaim S1
Thanks it was the ABS module but my traction control light is still on and my cruise control is still not working.
BT1-355
45
VP BT1 & BLOWN STATESMAN
Try resetting it, by disconnecting the battery
billy bob
VE S2 SV6
Check all your brake lights are working. I had the same problem a couple of years ago. Eventually figured out that the traction control and the brake lights are on the same circuit. Put a new globe in the rear window brake light and the traction control light went off.
