Vt air con compressor degas??
Status
Not open for further replies.
Vtv64L
Coffs hatbour
Vt v6 4l forced cold air induction
I need to replace the air con compressor but i am nit sure if there is still gas in it ive read a heap of **** that its bad for o zone i no this but isnt there a bleed valve i van just undo n bobs ur uncle or how much even is it to degas? I need help with this ****
oska
vx custom 600RR
There are two schrader valves (same air tyre valves) one on the high pressure line and one on the low
they are under the black caps on the AC lines and don't worry too much if you vent them to air, you're not going to destroy earth
Vtv64L
Coffs hatbour
Cheers mate do you no anything about altezza rear lights
mechanic
Australia
Commodore
Well done toolbag. It's dicks like you that created the need for refrigerant handling legislation.
Next time you release refrigerant to the atmosphere, do us all a favour - stick your head in the gas stream and take a deep breath.
Vtv64L
Coffs hatbour
yeah **** i did! it got me high as **** haha go shelf a pallet mate i dont give a **** i done what i needed to do
Vtv64L
Coffs hatbour
Haha i did do what i needed to do see go **** yourself buddy
accentstencil
71
Caboolture South, QLD
WH II Caprice, 5.7 2018 Equinox LTZ V
Wow, you come here seeking help and start abusing people, I hope you don't need more help because it probably won't be forthcoming.
tml678
2017 HSV30 Senator, 2002 Corolla..
Status
