you are correct all warning lights should show on ign activation before start
thats very rare for an idiot light to do silly stuff
check the bulb means ? .bench tested the bulb .visual -volt meter on the contacts -tried a new bulb,or swapped a working one
a bad earth or copper contact connected to the instrument cluster printed circuit fault
what does the volt meter say at the battery as its charge input
