VT Boot Struts how to fit?
Discussion in 'VT - VX Holden Commodore (1997 - 2002)' started by lil_oneblue, Sep 30, 2007.
  1. lil_oneblue
    lil_oneblue New Member
    HZ Sandman Ute, HZ GTS, VT Senator
    Got a bit stuck. im fitting new boot struts and the ones that i got i need to move the pin for the struts that is on the boot hinges. there is already a hole there for them. But how do i get the pin off? i tried a pair of vice grips and unscrewing it and it did not undo.
    anyone come across this before?
    cheers
    jason
  2. TheForgotten
    TheForgotten only human......
    quarantine
    VR EXEC
    why do you need to remove the pin?
  3. lil_oneblue
    to fit it into the other hole. the struts are too long to put it on the pin thats there.
  4. accentstencil
    accentstencil Well-Known Member
    Eschol Park, Sydney
    WH II Caprice, 5.7 2017 Captiva.
    Can't you exchange them for the correct ones? If they are too long the boot may not close.
  5. lil_oneblue
    they are the correct ones =). on the vt's there is two spots for pins on the hinge. unsure but other models maybe the same. there is twostypes of struts. ones for spoilers one for boots without spoilers. i need to shift the pin location to the other hole in the boon hinge (both sides) so i can then fit the correct struts (the ones i have).
    trouble is i can figure out how to remove the pins so i can fit them to the other hole thats already there........
  6. TheForgotten
    quarantine
    VR EXEC
    if they're the correct struts then they'll bolt in to the current position. if you've added a spoiler, the length is still the same, but stronger support. try taking out the rubber stoppers to open the boot further
  7. accentstencil
    Eschol Park, Sydney
    The pins look pressed in to me. They certainly don't unscrew. The pin goes right through the hinge and you would have to grind that knob off to remove it. But I still don't see why that should be necessary.
  8. lil_oneblue
    hmmmm.... see how i go =)
