Hi all I have a 1997 VT Calais My problem is that when I have low beam lights on - I switch to High Beam and the RHS lights switch off (or very dull). The same occurs when I have low beams on and switch on Fogs (RHS lights switch off or very dull).... *Low beams (and parkers) by themself work fine. *Parkers and Fogs by themself work fine. See a previous thread, not replied to, with the same problem (perhaps explained a little better): http://forums.justcommodores.com.au...ais-98-model-headlight-issue.html#post2074560 * I have checked all of the relays & swapped etc * I have checked / cleaned terminals at rear of headlights * I have checked / cleaned earth connections (at battery, inside front RHS inner guard wall, RHS strut tower near the fuse box) * I have checked wiring (as best as possible) from fuse box / relays to each headlight for shorts, etc. * All globes seem to be working..... Has anyone else had this or heard of this?? ANY Help / suggestions would be greatly appreciated!
Problem fixed all..... Blown fuse in relay / fuse box of Engine bay....so fricken simple after all that! Thanks to Bass308!
