VT Calais Series 2 V6 to HSV 355 Stroker
Discussion in 'VT - VX Holden Commodore (1997 - 2002)' started by Ash, Dec 30, 2013.
  1. Ash
    Ash New Member
    1999 VT Calais
    Good day people!!
    I had a few questions for you guys regarding my Calais.
    I own a Series 2 Calais which had a 3.5 V6 Eco-Tech in it. I did a bottom end on it and decided to go with a 355 Stroker out of a HSV VT Senator Signature after talking to sme people to which way I should go.
    The motor in and she is running (quite well). Some minor issues which I would like to sort out and hoping you guys can give me a direction.
    1: The Calais has speed control steering. After conversion, it is not working. The steering is very sensitive. Gets very scary at high speeds.
    2: How can I calibrate the Cluster to show the correct REV scale. It is showing an idle REV of 1500rpm. I think it is supposed to be around 700rpm optimum.
    Alos I was thinking about in a rear mounted Turdo system. Any pointers?
    Any advise would be greattly appreciated.
    PICS Attached
    Cheers,
    Ash.
  2. Ash
    Ash New Member
    1999 VT Calais
    Is there no one here who can help me??
  3. accentstencil
    accentstencil Well-Known Member
    Eschol Park, Sydney
    WH II Caprice, 5.7 2017 Captiva.
    You need a suitable scan tool to recalibrate the cluster.
    Are you using the power steering pump from the Calais, if not then that is your problem.
    Not familiar with turdos.
  4. Mk2
    Mk2 New Member
    VX Calais S2
    It needs more chrome.
  5. colourmesilver
    colourmesilver New Member
    Brisvegas
    VT1 98 SS 195i 5.0L 304 HSV ENHANCED
    What speed are you doing
  6. JMP
    JMP Well-Known Member
    VY 5.7 Berlina
    You need a tech 2 to reprogram the cluster from v6 to v8, holden can do this. Why the rear mounted turbo, why not underbonnet?
