been having problems with my abs oil pressure traction control lights comming on somtimes also a x on the climate control panel from what ive read it might be the abs module is there any way to test that this is the problem where can i get on from in sydney and how much are they
It sounds like an ABS problem. Somewhere in the following link is a description of how to test it:http://forums.justcommodores.com.au/showthread.php?t=49357&highlight=abs+module An X on the climate control panel indicates a fault with the climate control. Ebay often has cheap ABS modules if you need one.
