i think i have a problem with the abs module all the lights come up on the dash but i diagnosed it today and the only codes on the computer are codes 31 and 92 any help would be great
Code 31 is "theft deterrent signal missing". Code 92 is " low speed fan fault". There are no fault codes for the ABS Module.
31 = theft deterrent system problem 92 = Low speed fan problem There are no fault codes for the ABS Module.
so does it mean theirs no problem with the abs module or does the computer not log codes for the abs module or am i looking in the wrong area for the problem
Here's a link to how to test the ABS module. Again.http://forums.justcommodores.com.au/showthread.php?t=49357&highlight=abs+module
i give the motor a pressure clean the other week it migt not have helped the problem but it was never on before that
You may have got water in the electrical connector on the ABS module. Might be a good idea to clean the connector.
