vt clubby.. diff ####ed?
Influx69
Sydenham, Melbourne
VUII SS - 280rwkw
hi guys, i just bought a 5speed vt clubby 5.0L, went to drop the clutch in first gear it chirped then didnt want to do anything.. can anybody tell me what this could be? did i not realise that 5.0L are this **** or is there something wrong with my diff or something?
cheers, Rhys
Zeussy
SSM11K
Central Coast
Gen-F Clubsport, Rodeo 2.8 TD 4x4
First off, ####ing LOL.
Secondly, why were you 'dropping the clutch' ??
Thirdly, is there any noises coming from either the clutch/gearbox area, or the diff area? Like crunching/grinding metal noises that shouldn't be there?
Influx69
Sydenham, Melbourne
VUII SS - 280rwkw
isnt that what your supposed to do when its a manual?
cant really remember if there was any noises but after i took off after the attempt to do a burnout, when i was in 1st gear it was jerking. like it was cutting in and out when i had my foot on the accelarator
soop
Banned
Smithton, Tasmania.
2003 SS Commodore Series II
If the dif went bang, you'd no about it.
It'll rattle and clang and not want to roll any where.
Could have detonated the clutch too.
Influx69
Sydenham, Melbourne
VUII SS - 280rwkw
mmm dont know what it could be then? i have to change the leads tomorow and one of them is burnt. could this contribute to the problem?
Zeussy
SSM11K
Central Coast
You only do that if you're not afraid to break something...
With a V8, you don't need to 'drop the clutch' you find the friction point, and gently, but quickly let it out - So it eases the load onto the driveline. Not just dump it - resulting in a major shock load, and snapping things. ;)
Next time you're at the car, start it up, roll back and forth on a driveway (1st - reverse) with some one outside the car to see if the diff's grinding, or if the clutch has let go.
If theres any noises that should point you int he right direction.
If no noises, get under it and take the inspection cover off the bottom of the bell housing, see if theres clutch lining floating about, could have ripped the fibre clutch lining of the clutch it self. Or even snapped some of the fingers of the pressure plate?
Does it do the jerking all the time, or just that one time after you took off?
Zeussy
SSM11K
Central Coast
lol, if the engine is misfiring then yes, it would 'take off' anything but smooth.
graham7773
VT Acclaim Wagon
clutch, as said above, something broken in gearbox, tailshaft center bearing/uni, teeth off pinion or ring gear (or both), driveshaft cv shot. They the main ones. I may have missed something. Could be as simple as the burned lead/s
WyldOne
Wagon
Cars ####ed man, no good lol
Tree cutter
Tree cutter
Mt Gambier SA
VX Calais SuperchargedV6
It wouldnt be the traction control doing its job by any chance?
