VT commodore door wont open in or out can anyone help me to get it Open
chellechelle56
47
NZ
VT Commodore Berlina
Hi my VT Commodore door is jammed shut won't open from inside or outside can anyone please help with ways I can get it open, the window still winds down.
BlackVXGTS
Melbourne, SE
Which door, LF, LR, RF, RR?
figjam
Donating Member
Far Kurnell
FJ
Can you pull the snib button up ? You can reef it up with a bit force. If it comes off in your hand, a pair of pliers on the wire will unlock it.
Worked on mine, but if it doesn't, you have another problem.
chellechelle56
47
NZ
Thanks got it up this morning, but now it won't lock the door at all.
krusing
Melbourne, Bayside
Best to replace the Door lock mechanism,
At least you got it open and can remove the door trim to replace it.
the Wreckers would have them laid on, well they do here in Aus.
NeddyBear
Veteran Mountain Biker
Rubyvale, Qld
2004 2.5L Subaru Outback
Wondering how the door would become jammed?
chellechelle56
47
NZ
It's the locking mechanism it won't pull up or down it's just jammed. So wrapped it's finally open though.Thanks guys for your help this site is awesome. So helpful too.
figjam
Donating Member
Far Kurnell
FJ
It may be just temperamental, locking/jamming for no good reason, or dust/rust. Pull the mechanism out and give it some WD40 and a clean.
gungazza
67
west suburbs
executive vt 5.0lt VZ CREWMAN
pull off the door trim and give the parts a good spry with wd40 while you there put a little grease on the window winder cog
