haydo1801
Ok, so I have a 99 VT manual commodore, I have recently noticed 2 problems when changing gears in it. the first one has been doing it for quite some time now.. about 70-80% of the time I change gears i can hear a "doonk" sound (best way to describe it) coming from around the middle to the rear of the car at first I thought that I was because I was a bad driver...(haven't had a licence for long) and that I was still getting used to the gears and stuff but now that it is getting worse I kept trying to change my drive style to stop the sound, but it still sounds and kinda feels like the gearbox or something is going to fall out. the second problem that is only recent (last night and today) is when I was changing from first to second gears (only from first to second, no other gear changes) there was a terrible grinding sound as if I was trying to change gears without using the clutch, it only went into gear when I came to a stop. I have had a similar problem to this before but it was on every gear change and was easily fixed by replacing the clutch slave cylinder
all this stuff is new to me so if anyone could give any advice or help it will always be appreciated Thnx Guys!
