Vt commodore remotes died
fallenangel
innisfail QlD
vt commodore
Tried to reprograming two new ones with the maparts from supercheap n the tools tried two tools both go red saying error is there any reason as to y it could b doin this car is not deadlocked and tried leaving the key on for two hours a few times still gose red every time has anyone else had this problem
lout
61
Langwarrin Victoria
i assume you have two new remotes and the programming tool
check mode light goes out with original remote, check mode light goes out when turning to reds
assuming those checks are ok
disable anti theft with functioning remote, mode light goes out
turn new key/remote to reds
program new remote
if your current remote does not unlock car but still starts car
loosen remote head screws
turn key to reds. mode light goes out
remove remote head and install new remote head and tighten screws with ignition still on reds
program new remote
fallenangel
innisfail QlD
vt commodore
No i dnt have a working remote both my remotes died i have tried to new remotes to program one in i thought one was no gud so took it back got another one still wont program i can get the immobililser to go off if i leave the key on for 2hours im trying to program a new remote as both ones i have died wont turn the immobililser off
lout
61
Langwarrin Victoria
if you cant disable the immobilizer you cant use the maparts system
Lex
Geelong Victoria
VT Executive S1 V6 6 speed Auto Wagon
Have a read of this. Try it on your original key remote. Cost nothing to try. Don't worry about the battery part.
Hi
Last year l got my key fob copied, $100.00 No driving here, there, & everywhere in between trying to get it cheaper.
Earlier in the year my fob stopped working. Great l have the other one. Which of course works.
Couple of weeks ago l realised no spare. My original was still about so l thought l'd get a new case (ebay $4.75) & battery (jaycar $2.45).
Battery l got last week, case came yesterday.
I split the case with a large screw driver, then a smaller one. Checked with a multimeter how flat my battery was. To my surprise it wasn't flat at all. Showed full charge.
Anyway re shelled the electronics with the original battery, just pushed the case together, no glue, sealer or anything else. Put the original key in & screwed in the screws. Took out to car & pressed unlock button, no work, which didn't surprise me. Opened with key, no problem but the alarm went of. Put key in ignition & started it. Alarm stopped its noise. While key was still in ignition l pushed the lock button (on the fob & it locked) then pushed the fob unlock button & it unlocked. I believe this is called re-syncing. Cool. That is probably all l needed to do to have the fob working, was to re-sync it.
Just got myself a spare key & a spare battery for $7.20. Still cheap, so l'm happy.
Hope this can help some one else.
Lex
