VT commodore Thermo fans help needed
D
devilly
Guest
so i got a bcm and ecu to swap with the ones in my car, because i was sick of all the intermittent problems,to find that someone had been there before me, and had hard wired one thermo on and found a hidden button to turn the other one on.i rewired every thing back to standard and put the new ecu and bcm in no problems tried to start the car nothing happen total dead,i found a kill switch refixed the dodge wires,still nothing then i put the mode switch back on the car,it fired up straight away,5 secs first thermo turned on then 5 secs second thermo turn on, as soon as the second one came on so did the engine light.bugger ,changed the relays under the bonnet as mine when you shake them rattled.stopped tried to research and read my books to find what the heck was going on.so i did a reset as soon as i reset it no thermo fans and no engine light.ugrh then i went through all the wires and fuses next to radiator and then it hit me maybe its the fans them selfs.so it has four pins to connect to it went up checked me mates car they have 2pins connectors.so i got thermo fan with 2 pins.was about to go through another labor of love.and thought i would come on here and ask for help before starting the job.any ideas or thoughts ??also key fob works perfect
dirty hands
ipswich qld
magna
wierd fan wiring set up you have there ---and a kill switch
you know what your doing by the write up - is this a V6 ?
5 sec to start the fans i know not why ? and both running so soon
when you start the car the engine fan kicks in and stops as a sign its working - but not run on
I have been told the engine fan comes on by ECU signal -the air con only when air con is on
D
devilly
Guest
I have no gas in the aircon dunno if that changes anything,its very weird 1stfan on start up stays on and second fan cuts in and out so 10sec it turns on then 2secs off on for 10 secs and continues like that,its a v6,its a brand new battery, all brand new connectors for the battery wires and brand new terminals,oh and did the 5,6 bridge then have sat there and watched 12 12 12 12 12 no fault is coming up.
Nut Kracker
Donating Member
64
Echuca Vic.
VT SS 304ci (195i)
Check the wiring at the coolant temperature sensor and/or the sensor it's self.
dirty hands
ipswich qld
magna
no faults is good
the fan that cuts in and out --should be the engine cooling side .... but only when hot
the air con fan may kick in - I thought was always constant with air con on ---I never have paid it attention -- .
- but the compressor itself will shut down till it is re gassed
SavVYute
VY S V6 Ute Series II 2004
If the fan cycles on and off when the engine is cold it's a good sign the computer may be dead or dying.
Check the computer's earthed properly.
D
devilly
Guest
alright been working on it flat out today,i have taken out the coolant sensor put multimeter on it and it reads 1.88 ohms,checked mates car and his reads 2.45 ohms,have tried to research about the coolant sensor,cant find anything thinking of getting a saucepan with water in it bring to boil and see if ohms drop down at all.oh and it was covered in silcone and heaps of plumbing tape.
Nut Kracker
Donating Member
64
Echuca Vic.
VT SS 304ci (195i)
Have you checked the relays by any chance?
Check the resistance to temperature against this......
D
devilly
Guest
used braso and cleaned the coolant sensor it now reads 2.45, hmmm might go check that the correct relays are in it,maybe someone before me ,put the wrong type in...
D
devilly
Guest
thanks heaps :) for the input i'll go through it all and check properly.
