vt commodore
Discussion in 'VT - VX Holden Commodore (1997 - 2002)' started by nomoola, Feb 11, 2012.
  1. nomoola
    nomoola New Member
    queensland aus
    vt commodore sedan
    front left wheel rumble noise. all steering suspension replaced new,shocks springs etc, this happens at all speeds, swapped front to reaar tyres, noise still there, any light on this will be much appreciated.
  2. Jessie VT
    Jessie VT New Member
    VIC
    VT CALAIS
    Wheel bearing
  3. MikeCuzzy
    MikeCuzzy Jumping puddles
    Australia
    2007 VE Omega 3.6L
    +1 to bearings. Possibly suspension mounts if they weren't replaced.
  4. nomoola
    nomoola New Member
    queensland aus
    vt commodore sedan
    thanks for reply, wheel bearings, suspension mounts/bearings all replaced, brakes overhauled, new pads, could it be disk rotors, not replaced as yet.
  5. nomoola
    nomoola New Member
    queensland aus
    vt commodore sedan
    r u stupid?
  6. Dormant
    Dormant New Member
    VT Calais
    G'day Nomoola, all
    as you say
    Put the offending side up on the jack. Be safety minded and chock up the car so that if it falls, it wont hurt you.
    We will agrre that someone has been working under there, my first thought is that your wheel bearing has either collasped or running loose.
    Could be as simple as adjusting the bearing.
    when you grab the front wheel at the top and bottom can you rock it ?
    When you rotate the wheel is it smooth running or grumbling.
    What else do you think might be causing your problem?
  7. Killr6
    Killr6 tutut
    Hervey Bay QLD
    BA XR6T
    ah dreadful knocks, they are ####s!
    check for play in your brake callipers, all you need to do is grab the calliper and shake it, and if it moves and knocks alot, that can cause a rattle, maybe need a new calliper and new pins (i had this problem)
    when you say about the suspension and "etc" what else have you changed?? have you changed sway bar link pins ( they get fkn noisy ), z arm bushes?
    and also just jack your car up and check that everything is bolted in nice and tight.
    Cheers.
  8. nomoola
    nomoola New Member
    queensland aus
    vt commodore sedan
    Thanks Parabola, I'll check the calipers and see if they rattle or are loose, sway bar links and bushes, replaced also the z bar and bushes replaced, not too much has'nt been replaced. I'll get back to you.
    cheers.
