ant797
This guy that posted recently had the same problem after a mechanic fitted one he got genuine from holden https://forums.justcommodores.com.au/threads/oil-leak-behind-harmonic-balancer.270576/
Talking about wonky shafts i did a exstension housing seal on my vy recently and noticed the shaft sticking out had a lot of movement is this normal on a vy auto?This was the only conclusion i could come to.
Im 99.78% sure its the correct seal.
And i didnt do too much sealant in the keyway just a dab.
The yoke normally takes up the play as long as the bush isn't worn too much.Talking about wonky shafts i did a exstension housing seal on my vy recently and noticed the shaft sticking out had a lot of movement is this normal on a vy auto?
I just read it the Holden seal was the one leaking. If I read it right.This guy that posted recently had the same problem after a mechanic fitted one he got genuine from holden https://forums.justcommodores.com.au/threads/oil-leak-behind-harmonic-balancer.270576/
YepI just read it the Holden seal was the one leaking. If I read it right.
did you put a new seal in you sure the balancer was the problem and not just a dicky seal did you read the post i posted about a guy having the same problem from a seal he got from holden genuine and it was fixed the second time aroundOk, so i changed the balancer to a new one and everything appears to be ok now. Wish i had done this at the start! But i wouldnt have in any case as the balancer was the more expensive item of all the others.
The old balancer has a slight grove at the end of the shaft. Im thinking the rubber crank seal would sit right at it but the grove would be on the outside of the seal rather than in the timing cover.
Would anyone know how this is caused? Seems like it was the problem
Nah its the same seal (2nd seal i put on)did you put a new seal in you sure the balancer was the problem and not just a dicky seal did you read the post i posted about a guy having the same problem from a seal he got from holden genuine and it was fixed the second time around
Thats what i was thinking as if sandy grime got stuck on the rubber seal and Harmonic balancer shaft and as it rotates it slowly grinds away.Road grime, dirt, sand sticking to liquid gets under the seal and grinds it away I suppose.
