vt cv drive shafts drive axles how to remove and install
D
devilly
Guest
thanks for that jobs now complete :) i'll clean it down and keep and eye out for any leaks (touch wood) :)
Jae pod
33
vy commodore
hi devilly dis you have to remove the shock and sway arm to remove the cv shaft. Or do they slide out one the bolts are taken out
Jae pod
33
vy commodore
Do the cv shaft come out after the bolts are taken out or did you have to remove the shock and swing arm aswell
accentstencil
71
Caboolture South, QLD
WH II Caprice, 5.7 2018 Equinox LTZ V
They should just come out
Jae pod
33
vy commodore
So jack the car up remove the wheel. Then remove allan bolts from the cv shafts and the should just come out. Does the car need to be jacked on both side or just on side at a time. First timer here sorry.
Jae pod
33
vy commodore
Immortality
Staff member
Sth Auck, NZ
Jack up both sides and put on jack stands. Safety first.
Sabbath'
Redblock Jesus
80 Series// VFII Black Edition
As they are CV shafts, you can put a prybar in between the end of the shaft and either the diff or hub and pry it slightly to pop it out.
Jae pod
33
vy commodore
How would i go about getting the new ones back in if i have to pry the old ones out
