VT diff fit VZ??
Discussion in 'VZ Holden Commodore (2004 - 2006)' started by ismasiv, Aug 5, 2014.
  1. ismasiv
    ismasiv New Member
    Kingaroy
    VT manual/ VL turbo manual
    will a VT diff fit a VZ?? if not what different diff ratios can i get for my VZ... also will the diff gears out of a VT fit a VZ??
  2. Surfwagon
    Surfwagon Well-Known Member
    Sydney/NSW
    AMG Mercedes C63 Wagon
    No the VT uses the same/similar pinion flange to that used in VR/VS.
    The VZ run a different front flange also the gears are interchangable for the same model eg M78 or M80 but the later Vx-VZ has an extension on the pinion shaft to locate the 3 finger flange used on later versions.
    Better of trying to find the same diff out of a VX-VZ to swap over.
    What model diff is yours in the VZ M78 (V6) or M80 (V8) although all VZ's may be fitted with M80 diffs.
    What ratio do you want and what size engine.
  3. _R_J_K_
    _R_J_K_ Well-Known Member
    Zenki S14
    You can change the flange.
  4. ismasiv
    ismasiv New Member
    Kingaroy
    ok just a V6 and i have no idea what diff i have i'm pretty sure the stock gears are 3.08 and i would like to go to a 3.77.. i'll get under and have a look today to find out what it have.
  5. Mattde
    Mattde Member
    Milperra
    VX Executive S1
    If it's any help, most stock VZ V6's come with a 3.08:1 Ratio Dif.
    Or at least my exec does. Checked it yesterday.
