VT DRIVERS SEAT Headaches
Discussion in 'VT - VX Holden Commodore (1997 - 2002)' started by Tsunamix, Dec 1, 2008.
  1. Tsunamix
    Tsunamix Active Member
    VT 2
    Like everyone else probably, My drivers seat cushion has collapsed on the right hand side on th ebase. Ive already swapped out this seat once and lost my Drivers side airbag, now the cushion has gone again and I'm wondering what the hell to do.
    Ive had one seat repadded and it lasted about 6 weeks. The seat I swapped in was an SS which had better sides but the base still sucks.
    Is there a better tougher later model seat i can swap in that ideally retains the drivers side airbag, but gives me a better seat ?
  2. coasty
    coasty the voices told me to
    kanwal nsw
    vz equipe & vt berlina both v6
    mines still perfect. i just have problems with the back adjuster breaking.
  3. anonymousmoose
    anonymousmoose Member
    Audi A4 Quattro B8
    I have heard the VY seats will fit (confirm this)... also the VX
    Not sure if they are better quality. I've never had an issue with my VX seats. Yet I am a light weight guy.
  4. bdj_007
    bdj_007 Foose
    Beaconsfield
    2002 Holden VX Equipe SII
    vy will fit
  5. darren44
    darren44 New Member
    VT S2 wagon Berlina
    can you just remove the seats. what happens about the air bag. is it safe to remove and it wont go off.
  6. Calaber
    Lower Hunter Region NSW
    CG Captiva 5 Series 2
    Disable the air bags the same way you would if you were removing the steering wheel. It's then perfectly safe to remove the seat.
  7. BOGANV8
    BOGANV8 I gotta V8 whoot whoot
    Armidale
    VX 02 SS LS1
    Mine too have collapsed so yeah VY might be the way to go
    Doe the seatbelt buckle on the seat of a VY still have the same plug for the pre tensioners.... as the vx..
  8. darren44
    darren44 New Member
    VT S2 wagon Berlina
    sorry I dont know how to remove the steering wheel.
    is it the disconnect battery.
    leave 30 mins and then pull the seat out but never turn the ignition on while the seat is out ?
    thanks new to owning a vt commodore.
  9. BOGANV8
    Armidale
    VX 02 SS LS1
    edit just read you had side airbags.....
