lignum1966
Hi there , first up my Vt is Ecotech V6 , dual fuel , pretty stock , just Big CAI and Hi flow filter , Supercat Catback exhaust and Mace Enginering ECU chip .
(and of course dual fuel) . Christmas before last I put a fuel injector rebuild kit through it . (filter pots , o-rings and pindle caps)
Car was running so bad on petrol recently it would basically start and idle but stall out as soon as I went to rev it a little . Had been getting worse on and off for a while so
last weekend I removed the fuel tank , cleaned it out , replaced the complete pump unit that was very disgusting , dirty , blocked and rusty looking . Replaced fuel filter and fuelled the car up (I used Caltex 98) (Thats almost gone now so I'm gonna try something different but in this case I don't see it being that fuel) . Started pretty well straight away on petrol , revved freely and drove nice in a quick test . However all wasn't as good on the way to work next day after the car had warmed up !
So the car still runs fine on Gas , hot or cold . On petrol it starts anytime and runs fine when cold , but as it gets up to running temp starts to feel a loss of power and slightly rougher running (missing or surging) at or around around 1500 rpm approx which is 60kph in 3rd approx (and the same in top around 80ish) , and then generally starts to run worse and lose more and more power till undriveable or close to it . However I flick it back on gas and it runs just fine again . Now the Mace chip is a recent addition but the fuel problem seems to be there with that chip or the original ecu chip in use .
I don't know much about fuel regulators , cant find any obviously damaged or leaking vacuum lines , and (maybe stupidly) have sort of discounted electrical problems as the car always seems to be fine if I run on gas .
Hours of reading either here or on google and mostly getting sidetracked with other posts have made me no wiser (as to this problem at least) ... so I'm hoping someone here can !
Bazz
Bazz
