Sandst4rm
- Jul 10, 2018
- 192
- 181
- 43
- Location
- South Australia
- VT S1 Calais Ecotec - VP Ute 3800
UPDATE SORRY! Since this time the engine in question had spun a bearing, however it did run good for a bit, the problem was bad fuel from some BP around SA.
Youtube video to showcase the noise and trouble.
Really not a huge amount of ideas left.
This issue only became noticeable when i replaced my motor mounts recently.
- Have had a look around them for anything i pulled out of place... nothing.
- Replaced the spark plugs and ignition leads with brand new, no dice.
- Replaced my alternator because it was charging at 13.00 volts without load. Still running like dog sh*t.
- Checked intake for obstructions and leaks - found none.
- Replaced fuel filter - wasn't the problem.
EDIT: Since starting this thread I have tried;
- Cleaning MAF sensor with CRC MAF cleaner... no fix
- Checking multiple times again for anything i messed up while doing the motor mounts - still nothing.
- Cleaning throttle body and butteryfly (both sides) no change.
- Cleaning all areas on DFI and coil packs with no success.
- Checked with load and idle - with and without serpentine belt on car - didn't change
Any help would be appreciated. Cheers
