jacko1472
- Oct 12, 2012
- 1
- 0
- 0
- Location
- Brisbane
- VT(ll) 3.8L Ecotec
Hey guys.
I have a VT series 2 ecotec (auto) that has been having a few issues lately. The car will at basically anytime while running randomly start revving up (to about 1200rpm) then rev back down (to about 300rpm) repeat this process 3-10 times. Sometimes after this happens the engine turns completely off and struggles to restart. This happens modestly when the car is idling (for example foot on brake at the lights) however has happened under load as well. The engine when working is running very smooth with no obvious missing or anything else. This problem seams to happen when the car is cold though not exclusively. This doesn't happen every time the car is driven however is becoming more common. The problem also doesn't cause any engine lights to come on. So far i have had the car on the diagnostic computer (bridging the diagnostic port was showing nothing but code 12 'no faults') which yielded a crank angel sensor code. The crank angel sensor was replace (along with the harmonic balancer and the belt). Since replacing the crank angel sensor the diagnostics computer once again shows the same error (crank angel sensor). Also just fitted new spark plug leads. Have checked all obvious solutions and am out of idea's. Any suggestions?
Thanks in advance.
Thanks in advance.
