Vt ecotec to LS1 conversion problem
Discussion in 'VT - VX Holden Commodore (1997 - 2002)' started by skinnypedal, Mar 1, 2014.
  1. skinnypedal
    skinnypedal New Member
    Vt commodore
    Hi, I've recently swapped my v6 auto vt to a ls1 manual.
    I had a wreck and just swapped everything I needed over but I'm still having trouble with it.
    It runs and operates fine but i have no air con or cruise control, I have an engine light on and when I plug a scan tool in I can't connect to the engine to even get a reading of the code.
    Has anyone done this conversion before that could help me out?
  2. enroh
    enroh Member
    Regional S.E. QLD
    VY SS UTE, 69 CAMARO!
    Did you swap wiring loom and bcm?
    ----500rwhp corn juiced & boosted ls1----
  3. skinnypedal
    Vt commodore
    Yeah i did. Swapped all that
  4. enroh
    enroh Member
    Regional S.E. QLD
    Was it the same bcm as the ls1 car or another one? If its hooked up and running but won't connect I'd be going through all your wiring looking for dodgy connectors or a **** earth.
  5. skinnypedal
    Vt commodore
    The bcm was the same as the one from the ls1.
    Yeah I've had a look at the connectors, they all look fine
  6. Not_An_Abba_Fan
    Not_An_Abba_Fan Exhaust Guru
    Bunbury, WA
    Strange Rover
    The fact that it is running shouldn't be a security issue, but did you swap key heads as well?
  7. nathanVY
    nathanVY such boost
    Geelong, VIC
    2003 VY LS1 Turbo Calais, 2005 4Gen Liberty Wagon
    Is it a VT S1 or S2? If it's S1 you'll need to swap the wiring behind the dash over from an S2 VT or VX.
    I didn't need to swap the BCM for my LS1 conversion, what errors is the tech2 getting? or can't connect to PCM?
  8. _R_J_K_
    _R_J_K_ Well-Known Member
    Zenki S14
    Did you let the gas out? Which compressor are you using?
  9. michaelvts1
    michaelvts1 New Member
    SA
    Vt calais
    How come you need to change the s1 loom to s2 ? what’s the difference
