Cavaliere79
- May 4, 2015
- 12
- 0
- 0
- Location
- Beenleigh
- 98 VT Wagon
Hey everyone.
I'll admit to not being too ontop of electrical maintenance of my VT wagon, though I do have an electrical issue or two, which I need fixed for RWC, and my own peace of mind.
1) I have replaced the clock-spring and horn, but there is no response from horn buttons on the steering wheel, and the relay has been checked. Horn sounded by wire patching the relay socket. Power is going to the horn, and I've been told it's probably a bad earth connection.
2) The previous owner did a fan relay to connection above rad, to battery bypass, so the fan runs constantly when power is on. Bypass cable fell off and (a) how would i reconnect this bypass for a temporary fix, and (b) what would be the main cause for the fans not to work without this bypass cable, even if the car has been idling/revved for 20 + minutes to get the engine temp up. Ecu fault has been suggested.
Thoughts/Solutions?
Recommendations for the cheapest auto-sparky's in the sourth brisbane/beenleigh area?
Thoughts/Solutions?
