Vt engine light randomly runs ****? turn car off and its fine?
Discussion in 'VT - VX Holden Commodore (1997 - 2002)' started by VS-S-PACK, Jun 3, 2012.
  1. VS-S-PACK
    VS-S-PACK New Member
    Melbourne, BALWYN
    VT S 5 SPEED MANUAL
    Hey guys i have a 5 speed vt and just recently ( i believe after i put 91 fuel in, after running 98 ) i would drive for 30 mins or 20 and the engine light and abs light would turn on and the car runs like ****! why is this?
  2. som
    som New Member
    thorneside qld
    vt executive
    Real big chance it's only the T.P.S (throttle position sensor) Fairly inexpensive and easy to fit,from memory about $65 Good Luck
  3. VS-S-PACK
    Melbourne, BALWYN
    VT S 5 SPEED MANUAL
    thanks mate!
  4. milv8
    milv8 New Member
    bonnyrigg
    monaro cv8 04
    My sons vx spak 5 speed manual the same problem, as soon as the engine light comes on it runs like ****, replaced one of the knock sensor, the knock sensor if not working correctly will retart the motor and run like a dog. the vx have 2 knock sensors one is near the starter motor the other is on the oppsite side roughly the same area. knock sensor $81.
    the car runs well now.
    hope this helps
    regards
    Milv8
  5. Brett_jjj
    Brett_jjj Well-Known Member
    Tamworth NSW
    vs commodore
    It might be worth checking to see if any error codes are logged in the ECU seeing the engine light came on, it might give you an idea as to whats wrong. If you dont know how to do this simple error code test, check out the link below, its heaps easy and only takes a minute or two to do..
    http://forums.justcommodores.com.au/holden-commodore-how-tos/23665-checking-error-codes-vt-vx.html
  6. VS-S-PACK
    Melbourne, BALWYN
    VT S 5 SPEED MANUAL
    thanks guys!
