Vt executive 3.8 ltr petrol smell
Mrronny
vp
Hi I own a vt commodore 6 and I've noticed a bad petrol smell it comes and goes can anyone tell me how I can fix the problem
Nut Kracker
Donating Member
64
Echuca Vic.
VT SS 304ci (195i)
Geez mate, it could be coming from the fuel tank connections to some where in the engine bay and any where in between.
Next time it happens, have a good sniff around and try and narrow down the location of the smell.
Also check for any leaks.
Cheyne92
Maclean
Vx S pak
Make sure the fuel cap is tight as well, that will give a fuel smell if not done up all the way
Wombles
Cars cost too much.
My money's on the fuel breather lines.
nathanVY
such boost
Geelong, VIC
2003 VY LS1 Turbo Calais, 2005 4Gen Liberty Wagon
Yep, check your fuel cap is on properly. This happened to me a couple weeks back, put the fuel cap on right and all good now :)
If that doesn't help then check the system for leaks, make sure all the fuel line connections are tight.
Mrronny
vp
Cheers guys ill try the fuel cap first if i still get the smell Ill check the lines
Nut Kracker
Donating Member
64
Echuca Vic.
VT SS 304ci (195i)
Can you smell it inside the car, only from the outside, under the bonnet,
or all of the above?
Does the smell seem to come through the air vents?
Mrronny
vp
No more petrol smell I changed the fuel cap thanks heaps
NeddyBear
Veteran Mountain Biker
Rubyvale, Qld
2004 2.5L Subaru Outback
We had the same fuel smell and not good while driving so the cap was replaced with a Repco unit and yeah straight away no more smell.
