vt headlights
Discussion in 'VT - VX Holden Commodore (1997 - 2002)' started by luckyvt94, Mar 30, 2012.
  1. luckyvt94
    luckyvt94 Member
    Hobart Tasmania
    vz Thunder SS
    When I have my lights on low beam they only light up the road 5 meters in front of the car. How can I make them brighter or adjust them to shine further out
  2. MattaY[s2]
    MattaY[s2] BEA5TN
    Victoria, Melbourne
    VX II Executive
    lol i dont have a clue but some ideas might be to use brighter LEDS? or adjust your lights up slightly...
  3. lout
    lout Well-Known Member
    Langwarrin Victoria
    VX Executive S2
    1st make sure your lights work correctly
    check parkers, then low beam then high beam
    if they work there is a height adjuster screw between main and high beam bulbs
    there is a procedure to adjust, an underground carpark or industrial estate works best must have level road
    with tyres inflated correctly and half tank fuel
    drive up to a wall, switch lights onto lowbeam and mark centre position of lights on wall with tape
    back up in a straight line 7.6 meters switch to hi beam
    adjust horizontal aim (left/right) (adjuster screw between main bulb and park lamp) so it is in line with mark
    adjust vertical(up/down) so high beam is exactly centered on mark
    remove tape and you are done
  4. MattaY[s2]
    MattaY[s2] BEA5TN
    Victoria, Melbourne
    VX II Executive
  5. Holliday15
    Holliday15 New Member
    VX Lumina II
    Just buy some different globes....
    Vt's take H4 and maximum legal is 4000k
    I recommend narva lights, they seem pretty good. Go to their website or you can just get them at repco
  6. luckyvt94
    luckyvt94 Member
    Hobart Tasmania
    vz Thunder SS
    Ok I'll try that thanks
