VT Helpppp!
Discussion in 'VT - VX Holden Commodore (1997 - 2002)' started by matte_vt, May 22, 2011.
  1. matte_vt
    matte_vt New Member
    grafton, NSW
    vt series 1
    Hey guys,
    my vt is playing up what it is doing is when i take it from park to a gear it clunks and it is reving to about 3000rpm before it wil change from 1st to 2nd, and i also have no overdrive ( 4th gear) what could it be??
  2. graham7773
    graham7773 Active Member
    VT Acclaim Wagon
    Check your fluid level, if it is ok look at the colour of the fluid. Bright red, ok, brown not so ok, dark brown/black uh oh! Clutch material burned, trans is history. Red or brown fluid, try transmission service which means replace the filter and gasket and flush. If that does not work, replace the transmission. There are a couple of electronic problems also, check ALL of your fuses and relays, especially 20amp ones.
  3. rb26dett
    rb26dett New Member
    VT SS S2 A4
    Stuffed gearbox, mine was doing the same when I broke the 3/4 band
  4. scott-95
    scott-95 New Member
    Sunny coast
    Daily VE SV6 & L67 Manual Pig.
    hows reverse? sounds like your box is gone
