VT high beam issue.
Slapphappy
30
Roxby Downs
99' VT Commodore v6
Driving home last night, my high beam globe went out and I assumed it was a globe but after changing the globe over it turns out it's not. I get normal beam in both, then only one goes high beam. Also, when I just pull back my indicator it dims, when switched on properly it cuts out completely.
I wouldn't even know where to begin. Any advice.
Sent from my GT-N7105T using Tapatalk 2
Nut Kracker
Donating Member
64
Echuca Vic.
VT SS 304ci (195i)
Check fuses 29 (RHS) and 30 (LHS) in the fuse/relay compartment under the bonnet.
accentstencil
71
Caboolture South, QLD
WH II Caprice, 5.7 2018 Equinox LTZ V
I was going to suggest that as well. Strange things happen when one of those fuses blow.
Nut Kracker
Donating Member
64
Echuca Vic.
VT SS 304ci (195i)
Make sure the insulation on the plug that connects to the bulb is intact.
The plug is very close to earth on the back of the light assembly.
If that little wire clip that holds the globe in becomes detached, the bulb becomes loose and the plug could short to earth. (As happened to me once)
Slapphappy
30
Roxby Downs
99' VT Commodore v6
It's the fuse. But replacements just blow out instantly. Any ideas?
Nut Kracker
Donating Member
64
Echuca Vic.
VT SS 304ci (195i)
As suggested before....Take off the rubber boot/s at the back of the light and check for anything unusual,
like a loose plug, worn, frayed or burnt wires, loose globe fitment, bulb clip un done etc.
Slapphappy
30
Roxby Downs
99' VT Commodore v6
I've had a look and as far as my expertise goes it's fine.the wire clip is fine and the wires that go into the plug seem fine.
