Well if it's a rebuild everything that doesn't measure to spec. I'd be doing some top end gaskets , checking the intake for corrosion and porosity and new Bosch cap and rotor , leads and plugs then test the ignition module if VT still run them.
Then have the injectors serviced and flowed , clean the tank out and change the pump.
