vt into vs..??
xrsist
VT exec
hey guys just wondering if you are able to bolt vt drive line (motor, tranny, diff) straight into a vs? no hassles?
cheers for any info
simmons001
I like VS Caprices
54
WH Grange/VS Caprice S1 5.0
at a guess, i would say....maybe?
anything can go into anything given enough time and money :)
V6 or V8?
VT542
VF 1 SSV Redline Ute VS SS Commodore
Yes if it is a v8, as I have a VT motor and auto in my VS....Just use the VS wiring loom along with the VS distributor etc
xrsist
VT exec
thanks for the reply's
its a V6
whats the difference between a vs and vt v6 and auto?
are the diffs the same being irs?
cheers
Cursed CX8
Banned
Walking distance to FG meets
VY Adventra
u can use the vt auto in a vs, u just need to change some plugs around and same withthe diff. The engine needs to have the drivers side exhaust manifold changed to the VS one and the inlet manifold changed to the vs one so that the vs themp sensors can be used.
illlusion
VE SSV MY10
i have done a vx conversion in our daily i used vx v6 motor and auto box had to modify the exhaust on the drivers side as the both the vx and vs one was differant due to the bellhousing on the vx box very tight fit only have about 3mm clearance around the steering rack your better off using a vs box and i kept the vs harness just have to add a temp sensor to the themostat housing as vt onwards dont have it they only got a coolant temp sensor and the ecu sends the reading to the gauge and if u use a vt vx box you need to modify the selector and reverse it
ephect
Donating Member
VS Acclaim V6
illusion is on the ball, i am running a VT engine in my vs, tapped my original sender and all good. used my VS auto so didnt have to modify the exhaust.
xrsist
VT exec
great info thanks guys
