Check for codes bridge pins 5&6.
There could be no spark. Check for spark.
If there is no spark it can be the DFI module/CAS or even the EFI relay.
If there is spark the ignition side of things are good.
It could even be a communication failure between the BCM/PCM.
They talk to each other upon start up. The PCM enables the fuel system. Or even the PCM could be playing up
guys, mine happened again this morning, was kicking over and over and over but didn't started , tried it for like 5-10mins , then sudden started from nowhere .. i getting panic as don't know when the car gonna start or not gonna start ..
another thing i realised , it alway happen only in the morning. also, after the car started i can switch off and i can start it again every time , never have any problems.
thinking about getting new key but don't really wanna spend money if it won't fix the problem tho
what you reckon about the injectors , could be leaking over night and flood the plugs ?
Thanks for all ya helps
