vt l67 iac valve
Discussion in 'VT - VX Holden Commodore (1997 - 2002)' started by l6790, Nov 2, 2018.
Tags:
  1. l6790
    l6790 New Member
    tas
    vt 3.8s
    hey guys i have a vt 3.8s factory (l67)
    my iac valve has chucked it in however i have tried to install 2 new ones but everytime i start the car the pindle extends all the way and falls out.then the next time i go to start the car it can't get any air flow to crank over.
    lost for ideas accept for maybe the ecu is telling it to open to far?
  2. accentstencil
    accentstencil Well-Known Member
    Eschol Park, Sydney
    WH II Caprice, 5.7 2017 Captiva.
    If the pindle falls out then it must be too short which means it's the wrong IAC valve. I assume you are saying that it falls out when installed.
  3. gohrdrgomad
    gohrdrgomad Active Member
    Australia
    VxCaly57
    did you disconnect - power before remove/ refit. If you didn't ive herd it can create issues. You can disconnect -, remove/refit part then reconnect after 30 min past as it should recalibrate to possition/reset to my understanding.
  4. l6790
    l6790 New Member
    tas
    vt 3.8s
    this is the second one i have brought (differnet company) also done the same as the first trying the battery disconnect etc now
  5. l6790
    l6790 New Member
    tas
    vt 3.8s
    even after the battery method still shooting out in the chamber i believe that the one i have is to small as the old one will only pop out if the iac screws are left undone so have cleaned that one up and and regreased will try it when the car has gone cold again
  6. delcowizzid
    delcowizzid on holiday
    NZ
    в∞ѕтεכ √&
    There's a fat and skinny tip iac you are probably using a small tip one in a big hole
  7. l6790
    l6790 New Member
    tas
    vt 3.8s
    was just ready over the box repco gave me says vn to vt but being the l67 it qould be more like vt-vy?
  8. lout
    lout Well-Known Member
    Langwarrin Victoria
    VX Executive S2
    l67 iac is unique to that engine you need the larger one
  9. l6790
    l6790 New Member
    tas
    vt 3.8s
    awsome thanks guys for the help now i know what to source
  10. gohrdrgomad
    Australia
    VxCaly57
    yep sometimes it pays to be specific when obtaining parts from non gen suppliers for example. It's possible a procedure is required once fitted to set iac position also. From memory l turned ignition on then off before starting to set iac on a ls1 then once started the computer recalibrated its function. But it may not be relevant to your application. I dont have any written data to support this either.
  11. lout
    Langwarrin Victoria
    VX Executive S2
    the ecotech sets the iac valve at key off
    first start will be a bit eratic
    after it warms up, key off ,next start should be fine
  12. l6790
    l6790 New Member
    tas
    vt 3.8s
    hey guys still havning no luck have tried sourcing a larger iac valve so that it doesnt shoot out but however all the brands etc all come back with the same size pintle about 3/4 of the current one i have can anyone link a site etc qhwre i can get the larger ones
    guy from repco reckons its only oversized as its still the original one and the aftermarket ones are smaller :/
  13. lout
    Langwarrin Victoria
    VX Executive S2
    tried genuine holden?
  14. gohrdrgomad
    Australia
    VxCaly57
    try pec Australia
